SubRider
I'm installing my Bafang BB02 to the frame of my Optima Falcon 'bent (not to the BB shell way out at the end of the front boom).
The motor mount is a custom U-bracket, which takes the place of the BB shell in a typical BB02 mounting. The BB02 mounts to the U-bracket and that mounts to the frame.
An issue is that the "toothed" Bafang plate (which bolts to the electric motor frame) does not bite into the U-bracket (which has a lot more surface area than the edge of a BB shell.
I've been looking for toothed washers, but washers that are big enough are rare.
I'd rather not use an adhesive.
It is easy enough to drill bolt holes to fix the left side, but that is not an easy option for the right side because I don't want to drill into the gear housing.
I prefer to fix both the left and right sides.
Do you know of a solution?
Perhaps a thin "toothed sheet of metal that can be cut into something like a large toothed washer.
Cheers,
Cheers,
