The Toecutter
- Joined
- Feb 8, 2015
- Messages
- 1,375
Here's one that caught my interest:
https://www.youtube.com/watch?v=jOPvnh0k05g
[youtube]jOPvnh0k05g[/youtube]
Claimed 120 mpg at 70 mph and it seats 2 people. If it had some wind tunnel time to sculpt its shape, I bet drag could be cut by more than half. The engine could likely also use some tuning. Considering it seats 2 people, this efficiency isn't terrible. But overall, I think 300 miles per gallon at 70 mph is possible with some optimization.
This next beauty, a single-seater, was designed by Paul Elkins:
https://www.youtube.com/watch?v=2REj9LSsIvE
[youtube]2REj9LSsIvE[/youtube]
Without the custom aerodynamic body on it, he reached 57.3 mph on a one-cylinder 185cc engine. For certain, this vehicle's fuel economy is going to end up in the triple-digit MPG range in normal operation with that body installed.
According to a later video, it weighs 322 lbs complete(including body):
https://www.youtube.com/watch?v=LfKW0ARjlI4
[youtube]LfKW0ARjlI4[/youtube]
He describes it as "squirrelly" over 50 mph. Top speed claimed is 62.2 mph.
If it had the aerodynamics of my Milan SL velomobile, thousands of MPG at highway speeds is theoretically possible, even with its current weight and engine. His won't be that efficient, but it is still easily an order of magnitude improvement over most cars.
I really like his build, because it has many similarities to what I'm trying to do with my KMX trike. Except his is gasoline, and mine is electric/pedal hybrid. And his is much heavier a vehicle. I'm keeping to an intended 100 lb vehicle dry weight limit(ready to ride, including batteries, but no rider/tools/luggage/ect). I might go slightly over, but no more than 120 lbs for certain, otherwise the pedals aren't of much use if the EV drive system fails. Downhill, in both my custom KMX build and the Milan, I've been much faster than 62.2 mph. The Milan gets kind of scary at anything over 45 mph but has been almost twice that and isn't as bad as it seems once you're used to it, but my KMX feels deceptively stable downhill at 60+ mph on good roads(albeit, this was tested before I installed rear suspension and extended the wheelbase). In both vehicles, the brakes aren't yet up to the task, but the KMX may be in the future. The KMX feels fine at speed, and the previous build had no problem holding 45+ mph using the motor, which is why I say it's deceptively stable, because the brakes/spindles/wheels/tires it used were all ill suited to that use case. A spindle did eventually fail after hitting a pothole at 40 mph, so things can seem fine, then suddenly get very scary, or worse...
I'm sort of saddened Paul isn't going to perfect his build or make another. A longer wheelbase and a refined body design could really go a long way. I think his vehicle with that engine and low mass has 130+ mph top speed potential if he really sat down and decided to optimize everything, especially the body, and tuned the engine for a modest power boost, and it would do such while getting stellar fuel economy. Even as is, his build is damn impressive. I emailed him last year and never heard anything back though.
