Patriot said:Doc,
Since you have a Mongoose, similar to mine, you could do what I did. I made an addition to my existing 25lbs capacity Transit rack. It works really well. Since your rack has the same double seat tube support setup as mine, it may work. I made it out of simple 3/4" angle iron. What's really nice is the double tube support prevents it from any possible swaying when riding.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=10885
Doctorbass said:Patriot said:Doc,
That is a great idea and nice job for this model Patriot
But the bike i need to put the rack on are different!.. I have 7 bike to modify.. so i need a less complicated way!.. did you saw page 3 of this thread?.. I shown a pics of the similar bike i'll need to put the rack on.
Doc
:wink:
BVH said:ElectricEd, what are using for your seat post/rack clamp pictured above where your support arms land? I need a 1 3/8", nice looking clamp for the same purpose.
I was just reading this entire thread to see if that had been suggested yet. I have the Axiom Odyssee rack rated at 55lbs cap. and want to make sure it does not rotate on the seat post as others have mentioned.gerlewis said:Hi guys, I now have this same Topeak rack problem, where it sways as I go on a journey!
My idea is to create a better bond between the clamp and the seatpost, either by gripping both surfaces with a keying of somekind, or by using something like threadlock or superglue to create a permanent bond.
Ger
gerlewis said:good idea with the ball bearing, what you thinking, 4mm - 5mm?
A grub screw glued in place might do a similar job, though im not sure where on my clamp I could drill a hole to be honest.
I need to do something, as its not up to the job as it stands, swaying this way and that.
Ger
rguy56 said:There are implications to the seat post itself if the weight gets excessive.
I think it may work well to find two racks that nest well on each other and clamp them one over the other on the seatpost. If you were to do that and add struts between the two, I think the major limitation would be seatpost strength.
