auraslip
- Joined
- Mar 5, 2010
- Messages
- 3,535
1. "Set you lvc at 3.3/5/6v!" Ok. When you say that. Do you mean discharge until your pack hits that under load, or until the resting voltage is that low? If it's the former, it makes it impossible to test the absolute maximum capacity at real world loads. For example, I want to test from 4.2v down to 3v resting to get the maximum capacity my pack has. Well, under load it'll hit 3v with voltage sag, but once the load is gone it'll rest at 3.6v. Still mostly discharged I know, but I'm trying to find maximum capacity. The only option is to discharge at very load rates, but those are what you will see in real world applications. I'm trying to find max capacity so I know exactly how much headroom I have!
2. Specifically, when a battery sags under load and goes beneath the LVC does that damage the battery. Or is it going beneath the LVC while resting that damages the battery?
3. How important is compression while testing a pack? Bare cells will go up a few milivolts just squeezing them. I haven't tested this yet, but I'll have to try it out.
