Hi all,
I have a QS273 with a sabvoton 72150 (150A) and a 72V 40AH battery (150A BMS), while the motor works properly under no or little load when applying full throttle under 20kmph the motor will stutter and most of the time cause an overcurrent error on the controller. The display will stay on and so will the lights so I dont think it is the battery, the same issue also occurs when setting the maximum current to just 100A on the controller. I know that the motor has been repaired in the past using honeywell SS41A hall effect sensors so the phase wiring could be wrong.
Could this be an issue with the phase wiring as unless full throttle is applied under 20kmph the issue does not occur, at maximum speed and full throttle the issue also does not occur.
Thank you everyone.
Thank you everyone.
