zombiess
This isn't something you should do if you aren't comfortable working with LiPo
Just wanted to post a success story. By following AussieJesters directions I depuffed a cell in one of my packs. Now it's going to be monitored. My first charge was done outside (just in case) at 5A into a Turnigy 6S 5Ah pack to see if it would get warm, it didn't heat up at all. I normally parallel charge 8 packs at a time in a 40Ah configuration 6s8p. This cell has always been the weakest out of all my packs, but doesn't go out of balance if I don't discharge below 3.7V resting. I charger reports a resistance of 2mOhm which seems normal for my packs which vary between 0-2mOhm for each cell and an average of 4-6mOhm per pack. I do notice that when measuring the packs each one needs to be done several times as the cell values keep changing but almost always average out to 4-6mOhm total for a pack of 6S 20C.
All 8 of my packs have gotten a little soft from over discharging to 2.8-3.1V one time (my fault) to LVC set at 3.0 per cell. This one cell did puff up a little more than I liked and has been in that state for about 4 months. I used a small metal pin (tooth pick would have created too big of a hole) to very carefully create a very tiny hole in the crease and release the gas and then sealed the entire edge with hot glue quickly. If this cell puffs even a little, it's going to be replaced.
The over discharge was intentional. I should have stopped but didn't and rode it until the cutoff kicked in and the packs got pretty warm. I won't be doing that again, next time I'll walk it home. Based on other stories I've read this repair should be successful, but only time will tell. I know many on here are afraid of LiPo cells, but after watching all the videos of people physically abusing them and knowing how hard hard RC guys use them I'm not afraid of them, but I do respect them.
