Agreed. I find only pretty expensive forks function well with a front motor. But then you have to find expensive forks that have space to fit the motor and torque arms. Many many many suspension forks have no clearance for the motor case.
But even so, a fork that binds with motor under power may still work ok if you just roll off the throttle when you hit a speed bump or pothole. That's what I have right now on my commuter, a cheap alloy fork. Throttle on, it's a stiff fork, but if I see a big bump coming, I coast and it soaks up the big bump, saving spokes and rim. No dirt riding, so it works, sort of. 1000w, so with dual torque arms the motor is not breaking the forks. It take no genius to see this fork will die an ugly early death, and stop soaking up bumps even when coasting pretty soon. Likely metal shavings in the fork oil already.
Alsmith, If you replace a suspension fork with a regular fork, you need a suspension corrected, longer one. Same thing works the other way, if you put a very long suspension fork on a bike that didn't have suspension, it will ride funny.
