One note about the BBS02 kit..
The pedal thread on the drive-side stock crank arm went loose on me after 50 miles and the pedal kept threatening to fall off onto the ground while riding as a result, despite me constantly tightening it.
I replaced both crank arms and noticed something.. the chainring side would stick out about 10mm, causing me knee pain. I thought this was just my crankset, so i swapped out 4 different cranksets and saw that the problem was in the BBS02 drive's bottom bracket's design.
If your stock crankarm threads go crap on you, you can stick a regular bike crank arm on the non-chainring side, but you are going to need a chainring-side crank from a crankset that was designed for a wider bottom bracket, but 1 or 2 chainrings instead of 3 in order to correct the offset.
In my case, i have hooked up one of those cheapo walmart single speed bike cranks on the chainring side, and this corrects the offset enough to continue riding.
Will update with a pic later.
