kiltedcelt
So I noticed something kind of funky today with my MAC geared front hub motor. When pedaling I could hear sort of an oscillation sound coming from the motor, and even looking down I could see the power must've been coming uneven enough that the fork legs were showing a slight fore/aft flexing that seemed to coincide with the oscillating sound. Now if I stopped pedaling, and simply applied throttle the motor was just spinning and humming along with no noticeable oscillation, either audible or visible, even with trying to limit throttle output to the same watts as what I was getting from the current setting on my multi-position switch/CA V3. A few stats - 52v EM3EV battery, 25amp Infineon controller, MAC 14T geared front hub motor, Cycle Analyst Version 3 with most recent 3.1b upgrade, thumb throttle, 12 pole cadence PAS, and last but not least, the new-ish Grin 2-button multi-position switch which I have configured to offer assist from 50 watts all the way to 500 in 50w steps. Final note - I think I've sort of noticed this oscillation before but it was only momentary and I wondered if it was something to do with the clutch engaging/disengaging, and kind of wondered if maybe I should crack open the motor and see what shape the gears are in. The motor has probably 2000-3000 miles on it at this point. The other possible factor is that the battery was pretty close to being exhausted - it's been EXTREMELY windy here the last couple weeks and so I tend to run the assist at around 350 - 500 watts assist a lot when I'm either fighting those winds going in to work or coming home. So, coming home this evening I was on the last "fumes" of the battery charge, at least by going off of the less-than-accurate battery life icon on the CA display. This battery has 28.3Ah, but I've been getting quite a bit less because probably cold weather and lots of extra watts than I typically use for assist when the weather is nicer/less windy. The most I've gotten recently mileage-wise was about 80 miles, but I know this system as I have it configured can deliver more than 100 miles of range if I'm fairly conservative with everything. So my thought is: Was something funky going on due to the battery power getting low (that lame battery gauge showed about two pixels left while the Ah used was only about 20 - should have another 8 Ah available?), or, OR is something squirrely going on because I need to make some sort of adjustment to the "Gain Adjustments: Minimizing Surging or Speed Oscillations" as explained in the CA guide? Also, adjusting the Gain Adjustments seem to require having the bike raised up in some sort of stand so you can try to recreate the issue and make adjustments on the CA. Is this the case? I'm sure I can figure out a way to elevate the front hub motor/wheel while raising the rear as well so I can pedal the bike and get the PAS to work so I can recreate the issue. One last reiteration - Pedaling under pedal assist = surging, while throttle only/no pedaling = no surging.
