winiemo
Hey there,
i just got a an BBS02 and the setup is working good so far, even with a 7,5ah bottle battery, i have enough energy to make my way to work twice, which is quiet steep. I flashed the BBS-FW by danielnilsson9, so i can switch between normal and sports mode. Everything is working out fine, but i have the issue that i need to pedal too fast to make the PAS starting the motor. On the orignal FW, the motor started so fast, it even happened that i accidentally triggered it. Now i need 2-3 fast crank rotations. I set the starting angle to 45° but it didn't change anything. -Can someone explain to me, what i have to do? Also is there a way to set a smooth decay for PAS. When i stop pedaling, the motor really slaps and its loud. If i do the same with the throttle, it just buttery smooth stops giving power.
Best Regards and thank you!
