Anio58 said:
Is it safe to widen suspension forks ?
Amberwolf got this one right. I'm going to take your question at its most literal, though. And I'm going to assume that by "suspension forks" you mean telescopic suspension forks, not girder, leading link, or other exotic linkage-based designs.
A telescopic fork with cast aluminum or magnesium sliders can't be safely widened, full stop. Don't even try.
A telescopic fork with welded steel sliders (which is to say, the cheap and horrible kind) can be widened
safely, but only if you don't care about what happens to the suspension action. When you bend the stanchions out of parallel with each other, the fork will tend to stick-- compressed or extended, some movement or no movement, you don't get to choose. Since suspension isn't strictly a safety issue, it's not strictly unsafe to bend a steel suspension fork to a wider spacing. It just sucks.
Because of the geometry of telescopic fork sliders and arches, it also might be rather difficult to widen them without screwing up the alignment of the fork tips. They'll have a strong tendency to toe in when you spread the legs apart.
