Hi All,
Well I have decided to finally parallel my three battery chargers so I can bulk charge Voltron in 2 hours from dead flat, instead of 6. Not that the extra track time would have done me much good (I would have still burned out the motors, just sooner :lol
but since I'm riding a new track each time I might as well get as much time in the saddle as possible. I have two here, and the third one is still in Canberra with SplinterOz.
These Elcon chargers were purchased from Rod Dilkes at
http://www.EVpower.com.au, who gets them from Nancy at TC. They leave the factory dialled in to whatever voltage you choose (117 V in my case). The other cool thing is the charge enable plug, which is really just a circuit that turns on the charger. Rod's BMS master unit has a 'normally on' relay so that should one of the cell modules record a very high voltage, it will trip out and make this charge enable circuit open circuit, switching off the charger. When you have three of them in parallel, you need to devise a means to turn them all off or on at once.
Rod gave me a mud map of how to do this. Basically you have three SPST solid state relays where the activation coils are wired in parallel. The individual charge enable leads are wired into the output terminals of the relays. The activating circuit needs 12 V, so you have to apply 12 V through the same circuit.
Below is the mud-mad Rod drew for me, I found it very helpful.
Also, I have started to bog up the original tank I have for the RG. Someone has offered to fibreglass me a cover, as the polycarbonate one I have currently is not exactly ergonomically sound. The knee-divots were too narrow for the tank to fit over the battery packs, so this should fill it out a bit.
