Eastwood
- Joined
- Jan 13, 2021
- Messages
- 1,480
You have moved weight around in the chassis that it wasn't intended for so things change
Yeah for sure
On a sidenote, I actually revalved the bike this morning Lol., I couldnāt help myself
But it definitely needed to be done as yesterday I did some more extensive testing and itās still harsh over sharp squared objects, even with the compression clicker turn all the way out.
So after the re-valve this morning, itās much more plush and less harsh over squared Sharp objects.
Tweaked the low speed and high speed, Nothing too dramatic. Iām sure Iāll end up doing more re-valving once I have the final bike weight.
Next, I need to order the new main springs as Iām only using about 70% of the stroke. The race sag as of now for the forks is only 20 mm which is way way too stiff
According to race tech the Rmz 250 vs 450 the front spring rate is almost identical for my body weight so Iām thinking after I add the extra 10 to 15 pounds with the new battery, It shouldnāt be too much of a dramatic difference since race Tech has the 250 and 450 at almost similar spring rates for my specs.
RMZ 250cc .40kg/mm
RMZ 450cc .41kg/mm
My stock springs are .47kg/mm
