Paintpennn
Recently changed the tire on my stealth bomber clone. It has a QS273 clone hub motor. It worked perfectly before I took the wheel off to change the tire. I reinstalled the wheel today and turned the ignition on and the display lights up but I twist the throttle and nothing happens. Like I said I'm running a QS273 clone motor with a sabaton 72150 controller, SW900 display and everything worked fine before I took it apart.. I labeled all the connections so I was sure to connect everything the same . It's got juice. I guess error 10 is communication error. Anybody know how I should go about solving this problem? I don't really know. .
