i'm looking for a switch so i can switch between 2 batteries, so like two set of the two power wires getting switched betwen two controller power wires, so two three-way switches or one all-in-one switch\. it needs to take 100v 45a.
If they are the same voltage, it may be better to run them in parallel.ian.mich said:i'm looking for a switch so i can switch between 2 batteries, so like two set of the two power wires getting switched betwen two controller power wires, so two three-way switches or one all-in-one switch\. it needs to take 100v 45a.
dnmun said:you do not want to run the two packs down separately. combine them in parallel and use them like that and charge them both together too. they will last longer and you will get more power out of them. do not put a switch in between them.
Monstarr said:Why can't u simply use a Anderson SB50 switch configuration?
Much cheaper imho than a high current DC switch.
dnmun said:yep, did not read the part where you said one was lipo and the other was canned lifepo4. you will need to use high current diodes to combine these two in parallel. there is not much difference in voltage between the two packs so a 20V schottky is about the lowest i have seen. that keeps the forward bias to a minimum so you don't make a lot of heat.
so figure out how much current you need and then you will know what size diodes to use. you don't wanna have a lipo pouch pack in parallel with another battery without a diode to prevent it from being overcharged if one of the lipo pouches goes flat, 0V.
hardym said:I found this DPDT switch with a "center off" for $15, shipping included, which seemed too good to be true:
http://www.goodluckbuy.com/szl9-32-...h-combined-switch-rotary-switch-32a-440v.html
I think this is an AC rating. The actual switching current to charge the controller cap will be way higher. The dc rating of the switch is generally much lower than the AC rating.
Darrel
dnmun said:yep, just connectors instead of a switch is simpler.
if you combined them in parallel you would have to use a diode to prevent charge flowing from one pack to the other. since your lifepo4 pack is 16S it would charge up to 58V and the lipo 12S would charge up to 49V so the lifepo4 pack would try to push current into the lipo and it would result in the lipo over charging and possible being damaged or going into thermal runaway.
but by combining the packs in parallel you would reduce the current demand on each pack so they would be able to deliver the current without as much power lost in the internal resistance that these lithium ion storage cells show when called on to release those ions from their storage spots inside the cathode matrix of the cells.
the lipo would discharge down to about 12S X 2.8V = 34V or so and the lifepo4 would discharge down to about 34V or so and the two packs would be totally discharged at that point.
if you had a diode on the lipo pack the regen would block the lipo from accepting the charge, but if there was no diode on the lifepo4 then the regen could recharge the lifpepo4 pack. but if the lifepo4 was pushed up in voltage by the regen then that voltage would not drain into the lipo either so it would remain protected from overcharging.
since your lifepo4 BMS would protect the lifepo4 pack, and the cellogs that monitor the lipo would alarm if the lipo was below the cutoff then you would have some measure of protection of each pack while in operation.
since you decided to just use each pack individually and pull the full current from each pack sequentially, this is more of a rhetorical exercise and will just give others an idea of how to approach the combining in a more analytical way. the one diode you would need capable of 20V25A, .45V forward bias is only 28 cents from mouser.
10A is right, but you are wrong it is a dpdt switch that switches one batter pack to anotherKin wrote:
Uhhh, wineboy, to clarify, because someone might read your link, the currie switch isnt going to help you here....It just switches the controller on and off switch. It's only like 10A
