Dunhill_BKK said:
As an Aussie I"m aware of the Elation kits, but I didn't know they had LiFEPO packs.
What do you think the difference would be between the elation-type system running through the gears and a geared hub? I reckon that one of the geared hubs, mentioned earlier in the thread might be comparable?
They are both different, so depends on what you are looking for.
The geared system gives you heaps of flexibility, for climbing hills, low speed running, or windy conditions, without loading the battery.
You can also gear the system to match your own cadence, or for a personal preference, like gearing high for higher speeds, or gearing lower, to give you assist at lower cadences, at the expense of no/little assist at higher speeds/cadences.
For instance, I had mine geared down to a max cadence of 100 rpm, and used as little continuous power as 3.9 w/km.
Doing this would give you an extended range, at the expense of speed.
My trike, on the other hand, uses a small geared hub motor, that at 36v, gives me an unloaded speed of 55 kph.(It is geared for a 20" wheel, and it is mounted in a 26" wheel) Practical speeds are around 35 kph, and sometimes up to 45 kph, depending on wind and terrain. With pedaling, I have seen over 50 kph.
Haven't drained my battery to cut-off, but it is only a small 10 Ahr SLA pack, and have done better than 20k's. Also haven't connected my 'Watts Up' meter, so don't have ant empirical data on motor current draw or whr usage.
The hub motor would be better from a maintenance standpoint, and maybe more suitable for you in a relatively flat terrain. The geared hub definitely gives you more flexibility over a gearless hub motor, and as I have found, quite adequate performance. (My trike weighs in at over 40 Kg!)
With a 10AHr LiFePo4 battery pack, I would expect a 40k+ range, and a weight reduction of about 8-9 Kg!
My MTB with 24v/10AHr LiFePo4 pack weighs around 22 Kg, and has a range well in excess of 40k.
Mind you, I do tend to use my packs hard, so a more conservative use of power by moderating the speed somewhat, should see a comparable increase in range.
As for power output, notwithstanding the legal aspect, I would tend to look at a small geared hub motor at 36v for good performance.
To stay relatively legal, you would be looking at a 250w/24v system. Well 200 watt is legal, but we could see an increase in that to 300 w, but from a law enforcement point of view, is really splitting hairs. Probably never become an issue.
If you go for a hub motor, you will then have the choice of front or rear. Front is simpler, but will require a good solid, steel preferably, fork.
Rear motors tend to be limited with gear choices. My hub motor can take a 7 speed screw on cluster, and that's about it. Some motors take even smaller gear clusters. So depending on you current gear system, that would be another consideration.
Have fun working out which way you will go, and above all else, I know that you will enjoy the ebike experience! It's a great way to get around and commute.
Keep us posted on you get on.
Cheers!
