Hi Lalaland.
lalaland said:
truth is it is slower with the motor than without it
I am sorry, but this is a total contradiction to over 3 years of our own testing, and comments from a large number of clients. If the motor is not operating, it freewheels and add only 6kg of weight, so hardly a 'ball buster' to cause a slowing down.
At the other end of the operating spectrum, if you are pedalling faster than the motor is set to rotated at then you can change anyone of the FOUR gears rings to tweak to your ride style.
I am an overweight 50 something person, and I am able to sustain +40-45kph for an acceptable distance for most on a Hybrid with 200W system, and I only ride once every blue moon nowadays.
Next, if you are halving the time of one leg of the trip, yet 'is slower', I am at a loss. I understand what you are suggesting ie; you are able to better overcome the doctor, but you clearly are still completing the journey
faster, hence at more speed than if you did not use eLation.
Finally, how can any electric system, let alone the eLation, impact on comfort and safety? Electrics does not impact on riders ergonomics and safety is always the responsibilty of how the rider rides (electric of not).
Cheers
Allan
PS. If you check into it a bit more you will find that the CA used as a limiter will not avoid the legality of Aust regulations. Been there, and argued strongly with DOTAR about exact same thing. You will need to be FULLY truthful to get correct answer. ie; advise them that the END USER has the ability to easily change the power limit. Naturally, you could always structure the question to get the answer you want, but would then suggest you get the answer in writing also.
