luciorossi
- Joined
- May 28, 2013
- Messages
- 11
Hi guys!
This is my first post, my first build and long time since I was driving a bike actually. I want to describe all the steps I went through and the problems I encountered, my likes and dislikes about this build hoping someone can find here the useful information I was missing when I started, and have the chance of asking the Forum for helping me solve the problems I'll be surely challenged with in the future.
But first things first. What did I buy for this build? Here is a list:
- Tern foldable bike model Link D8 with 20'' wheels (you can check the stats on the Tern website which is very well organized)
- qbbikes.es "Efficienced" kit 350W HT PB SS 36V 11,6Ah rear wheel (check the website)
- bike repair toolset (on Amazon)
- threaded freewheel sprockets (8s 13-32t) close to the original (8s 12-32t) (the kit doesn't come with the freewheel. Remember to put it in the order if you buy from them)
- 2 bottle cage universal brackets (Decathlon)
- spiral cable tidy, cable ties, a small file, sandpaper
- threadlocker fluid
Extra tools/stuff you may need:
- Wrenches, Allen keys, Screwdrivers, whashers, bolts, M-screws of different sizes...
Problems encountered:
Motor Choice: It was hard to decide what kit to buy but eventually I decided for the high torque (HT) one since I live in a hilly city, and for a 417,6 Wh battery for good autonomy. My daytrip is roughly 20 km I climb only at the return so I should have plenty of "juice" (hope so). The motor is a MXUS 350W I didn't want to put more power since the bike is a foldable and also I didn't feel like buying on EM3ev or Greenbikekits or BMSbattery where I had to make too many choices (maybe next build). I chose the MXUS since I wanted a Geared motor on the Rear wheel (check electricbike.com to know why... very good website btw)
Freewheel: Qbbikes suggested me to take a "freewheel" motor model and not the "cassette" type (don't know why... probably they don't trust the mxus cassette). Anyway this forced me to change the sprockets (and unfortunately the Link ones are non-standard). I still don't know if it was a good idea or not, but remember, once you screw the sprockets on the motor it is very difficult to go back, if you try you will probably unscrew the motor lid and not the sprockets. I tried to do this because at first I noticed something strange in the freewheel (I'll discuss it later) and I wanted to dismount it but I didn't have any grip or vise to separate the motor stator from the freewheel, which made me upset!
Mounting the battery as a bottle cage was no easy task because the threaded holes on the Link D8 are way too close to the folding hinge. I had to use 2 universal bottle cage brackets (Decathlon) to adapt the battery bracket to the frame (I'll show the pictures later).
Dropout dimension: The MXUS motor is meant for 135mm rear fork dropouts the tern Link has 130mm dropout, anyway the MXUS comes with 2 dropout spacers which are (to my opinion) too big for what's needed, so I substituted them with a couple of washers. It was easier to mount the motor, with less strain on the rear fork, which (I think) gave me a problem in the freewheel (making a strange sound and "biting")
PAS Sensor: the sensor coming with the kit has a transducer which can easily touch the magnetic wheel. I had to bend it a little, but it works.
Dropout eyelets: As in any build I saw on the internet they have to be properly filed in order to fit the motor axle in the fork. I tried to to this as little as possible
And now the first picture: the sprockets mounted on the motor wheel
