Ianhill
- Joined
- Sep 25, 2015
- Messages
- 2,872
It makes alot more sence to me now so if someone said to me I have a 2000v ebike I'd know alot better.
I'm still of the opinion though that if the shell becomes live to dc inside you will be fine unless you have a path to ground and if the shell has a ground live fault then it's going to activate the protection near instantly and will only shock anyone at potential with a path to the battery ground. If a door was opened with a live shell and stepped out then I not sure on that outcome i have faith there would be a warning chassis live shutdown before anyone got hurt.
Crashing in the lake is a good point it's not going to be the best outcome at all in dirty water the occupants will be rigging along with the fish so there need to be massive thought to safety and an explosive disconnect of some sort.
There's a man that can pass 1 million volts through himself but it's controlled http://www.wondersofscience.org/sfs/MILLION.HTM
This is why we use 50/60hz ac in the home its is the best at throwing us off the supply dc and high frequency can hold us on and I've had a work mate that got stuck on a dc lighting circuit and cooked his hand phase fault across about inch of his hand cooked it well and had skin grafts etc ended up with a big dome like an egg in his hand.
