safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Complete Analysis
My goal here is to gather every possible piece of information published for the BMC motor. I'm looking for things like the maximum rpms, no load current, inductance, internal resistence, etc. I'd like to also assess the purchasing options. (where to buy it) In the end I will do my very best to create a spreadsheet that accurately models all the parameters of this motor so that (like with the Unite Motors already modeled) it's possible to run simulations of what they can do.
36V
Rated output wattage 738
RPM @ rated wattage 3116
Efficiency (%) @ rated output 86.8
HP @ rated output 0.989
HP @ 30 in/lbs 1.345
Shaft, for Currie bike drive "D" shaft
Rotation viewed from shaft end CW
Input Voltage 36.0
Current @ rated output, Amps 23.6
Current limit, Amps 35
Motor weight (lbs) ~5
Motor dimensions H=3-1/4" D=5"
(black) Controller weight (lbs) ~2.75
(black) Controller dimensions L=7-3/32" W=3-1/4" H=1-7/8"
(silver) Controller weight (lbs) ~2.50
(silver) Controller dimensions L=7-3/8" W=3-7/8" H=1-5/16"
@ 48V
Rated output wattage 883
RPM @ rated wattage 3730
Efficiency (%) @ rated output 82.5
HP @ rated output 1.184
HP @ 30 in/lbs 1.545
Input Voltage 48.0
Current @ rated output, Amps 22.2
http://www.evdeals.com/Motors.htm
http://powerpackmotors.com/Powerpack-enhanced-shipping_included.html
36V
Input Voltage 36.0
@ 48V
Input Voltage 48.0
