Lyen
It is very important to use high temperature wires for your battery. I have another incident a couple days ago with my 48V 10Ah LifePO4 pack. This is a completely different issue and is not related to the incident I had previously > http://endless-sphere.com/forums/viewtopic.php?f=14&t=18577.
As you can see from the picture, the BMS some how got too hot inside the rack bag and started to cook itself. Fortunately, the burning smell was giving me the hint to pull over and do a visual inspection. The battery wire had partially melted on top of one of the MOSFET but luckily did not touch the metal surface area or otherwise I am in deep trouble.
Now all I have to do is to replace the wires and put the MOSFETs flat on the circuit board to make it works again. I think I got lucky this time for not generating another fireball behind my butt.
