Geez, I can't believe I've missed this thread, especially since I've known Matt for several years. :? The helicopter he mentions a couple of times is an absolute work of art, with a number of extremely innovative features. The metal work is beautiful, very polished, with a high "bling" factor.
I'm not surprised the Maxamp 10Ah packs are so light. These are mid-range, form a performance point-of-view, but pretty affordable, when compared to the 30C+ higher-end stuff. One caution I would have is that might want to consider adding an LVC capability, as it is quite easy to run these down to where they dump, and that will kill these LiPo cells just as easy as the LiFePO4-type cells most are using around here for Lithium-based solutions.
My actual first foray into the ebike realm was trying to adapt an RC-based setup as well, although it was caveman crude, by Matt's lofty standards.
This first one used a Hacker A60-18L outrunner, and a modified geared reduction, based on using glass-impregnated nylon gears, from one of the larger helicopters we play with:
The Controller is an uber-expensive ($400) Kontronix Power Jazz 63V model, which is good for 120A continuous, and 200A peaks. It too is USB-programmable, like the CC PHX HV 110, although it doesn't have quite as many options.
What I did was mount this on the down tube on my Townie, and then had the secondary shaft sprocket drive the large chainring. Although it worked, it just had too much power for the geared setup. I switched to a belt drive, but shreaded the belts in quick order. Way too much power.
I then switched to a different setup, using a big inrunner motor, from Steve Neu (http://www.neumotors.com), which had a hefty (by RC standards...) 6.75:1 planetary gearbox:
This solved the gear stripping/belt shredding problem, but this beast is $500, without the gearbox, which is another $200, I think.
In the end, it was not having a freewheel up front that got me off of this path, and into the big Clytes.
I've always had it in the back of my mind, though, that making use of the existing bike gearing, to get the torque advantage, is still a better way to go, mainly because you can get away with a smaller/lighter motor. This is why I bought the Cyclone 1000W kit, although I haven't had any time to do anything with it just yet. In any case, after I get the first one of these done, and find where the inevitable pitfalls/weaknesses are, I would eventually like to revisit trying an RC-based solution.
In any case, great work, Matt. As usual, the quality of the work is amazing.
I can't wait to hear more about your fine-tuning and tweaking. I know you will keep changing things here and there, making small improvements. Such is your nature.
-- Gary
