recumpence
1 GW
Glad to know it will work with my E-Logger. Another $150 goodie I already own that I can make use of. Actually, that one item will give me more information than any other single gadget.
So, I just came in from a full throttle (never let off) 6.5 mile ride at 38mph (hit 40 on a couple occasions). The roads were hilly and I got hard on the throttle the 4 times I had to stop (intersections). So, this is an absolute worse case scinerio. My power consumption was 26 WH per mile on that ride.
So, with this motor, I am at 16 WH per mile at 20mph if I nurse it and 26 WH per mile at 38mph if I am hard on it.
Seems like a pretty good overall efficiency for each. It could be improved on of course. My next task on this bike is a secondary drive consisting of a Plettengberg 10-18 on 24 volts (already have the motor, cells, and ESC for it). That would be good for 400 watts continuous. It should be good for gnetle cruising 16 to 18 mph with the powerhouse motor for high speed, high power running. That seondary drive will be ints own completely separate drive system mounted just forward of the rear wheel under the dropouts.
Matt
Matt
