johnrobholmes
pervert- http://www.danscomp.com/512039.php
GGoodrum said:I then switched to a different setup, using a big inrunner motor, from Steve Neu (http://www.neumotors.com), which had a hefty (by RC standards...) 6.75:1 planetary gearbox:
This solved the gear stripping/belt shredding problem, but this beast is $500, without the gearbox, which is another $200, I think.
In the end, it was not having a freewheel up front that got me off of this path, and into the big Clytes. I've always had it in the back of my mind, though, that making use of the existing bike gearing, to get the torque advantage, is still a better way to go, mainly because you can get away with a smaller/lighter motor.
-- Gary
GGoodrum said:The P62 is what is on the 2215-3Y pictured above. It is a beast, compared to what I'm used to seeing with these type of gearboxes, and uses high-quality needle bearings internally. I believe these come from Germany, or Switzerland, I can't remember. In any case, the combo should be able to supply plenty of power. Steve is famous for building extremely efficient motors. He uses only the highest quality steel in the stators, and the best magnets available. The stators are hand-wound.
The kV of this motor is 480 rpm/volt, so with the 6.75:1 reduction, it would be pretty much a drop-in replacement for the Cyclone 1000W motor. At 52V this spins at about 21000 rpm, which is coasting for this motor, which can go as high as 60,000 rpm. I know Steve has tested them even higher. So "overvolting" them is not an issue, but geting an RC-type controller to go beyond about 60V could be a problem.
Anyway, fun stuff.I'm definitely going to give the 2215/P62 setup a "spin", hopefully in the not so distant future.
-- Gary
recumpence said:Gary rarely checks his threads. So, it may take a while for him to get back to you. :wink:
Those gear cases are not extremely noisey, but they are not silent either. Kind of hard to explain. I am not sure how they would sound driving the loads we are seeing.
Oh, I have been doing a lot of testing. My efficiency keeps improving. I am getting used to the characteristics of my motor and my wiring changes have helped.
Matt
GGoodrum said:Sorry for the delay. As Matt points out,I've been busier than a one-armed paper hanger lately, and it just got worse this past week, as I've taken on a new consulting job.
The P62 is actually pretty quiet, by itself. Not much noiser than the motor alone. The Cyclone setup is really noisy, by comparison, but most of that is in the chain drive to the front sprocket. The freewheel might be a contributor to the noise as well. When I finally do get time to try this on my 16" Dahon folding bike, I'm thinking of switching to a finer pitch chain for the motor-front sprocket stage.
-- Gary
