Thanks for bring the thread back to the real topic.
Safe, Miles, others, the discussion you're having is useful, but this is not the place for it. Please take it elsewhere, like a new thread. Thanks.
1. How can a motor that small, running a 10,000 rpm have a long life? In RC it's running for minutes without much load (?), whereas driving an ebike for thousands of miles...?
Remember, it isn't that small of a motor; It's the size of a soda can. In RC it is designed as a motor for larger planes, in the 15-30lb range, running continuously at 2kw and up to 4kw to climb. The motor he is using and others like it are not designed for a few minutes use at low load (if those were your needs you'd use something much smaller, lighter, and cheaper, like a $20 ~200w outrunner.) It's a relatively expensive motor, and as such meant to last a while.
Your mind's eye fools you. A motor's power output is not directly related to its size, but rather the product of its speed and torque. Because (gearless) hub motors spin so very slowly, in the 100rpm-1000rpm range, they need to be heavier and larger to produce enough torque to do the job. Because we're looking at low-rpm motors and 14mm axles so often, his high-RPM motor looks weak, puny, and fragile by comparison.
For whatever reason, these RC motors are super small, yet extremely powerful...
That's why: the high RPM.
That's because of exact manufacturing and strict quality control. :wink:
Also, the motor's bearings and shaft will be subjected to much less than those of a hub motor. When he hits a pothole, the weight of the bike and rider won't be sent as shock through those bearings and shaft spinning at 10krpm. This more than anything makes that motor last.
What I cannot believe is how little heat I have. The controller runs cool, the motor runs cool, the pack runs cool. Everything just runs smooth and cool!
Under what use patterns? How fast, for how long, over what terrain and with what weather conditions?
I get the feeling that you're trying to measure things with a DVM poking somewhere while trying to ride. I think you need a CycleAnalyst. They make a shunt-based model that can plug in between your battery and ESC.
I bet you're surprised at how cool it is zipping you along at 25-30mph. Remember, though, that cruising at those speeds you'll only be using 200w-400w at the wheel. For a motor, controller, and battery designed to provide 2kw-4kw, I sure hope it would run cool!
I really want to know the limits of the machine. Can you please do a top speed test, and measure current draw at that speed? Or rather, more than one with different gear ratios. And some hill climbing and headwind tests?
