The only really limiting thing with the friction drives talked about most on this forum is the controllers used. You add sensors and use a Lyen controller with a 63mm can motor and have no fear, you will make it over almost any hill
. The sensor less controllers are just so simple cheap and easy to use they fit the idea of low power commuter friction drives very well. Personally i built a friction drive with a sensored 50mm can motor driving a roller on the wheel, could easily start from a stop and more then enough power to hit 35km/h. Could also flip the bike when i pulled the throttle without sitting on the bike
It was my first ebike and i would have kept it but i frocked up the batteries and thought it was the drive that was shit......my bad
To keep it simple, you could get a 12fet controller, a Turnigy 130(Has slots big enough to fit sensors into, low enough KV to run a high voltage without having to run a roller on the tyre, bigger roller on the wider tire = better contact for driving) and with that you could pump 7kw into the wheel, you would probably need to go for the fattest rear tyre you can get, even a motorcycle tire.
http://www.motorcycleforums.net/forum/paddock/11354-friction-drive.html
Talking about a 300+kg motorbike with a friction drive, google is your friend
