One advantage you might be able to exploit would be fitting rubber-friction pads where your knees are next to the faux tank. I always appreciate being able to squeeze my knees against friction pads during hard braking. It keeps your upper body more relaxed and able to respond with finesse for both steering and hand controls.Sean9002 said:As nice as it would be to fill all that space with LIPO, it was very uncomfortable sitting so bow legged.
Noph said:Hi.. This is nice to know someone is working on the same frame build. Love it. Thanks for sharing.
nicobie said:How's the clearance for the forks? Looks a bit tight. Maybe it's just the photo angle...
gogo said:Thanks for posting this up.
Bicycles with crowns that end underneath the headset require that the handlebars use only a central stem attachment. When I see forks like yours with the handlebars so close to the tubes, it seems like an opportunity missed for a robust attachment.
Samd said:Heya Sean,
stuck in Malaysia with no tinker time, you are my vicarious builder buddy! get to it!
I forgot I owed you that rear tank info.
If you scroll to the bottom of Ron's excellent link below and find the sportsman flyer I think they also sell the tanks between seatstay and rear wheel.
https://www.electricbike.com/more-boardtracker-e-bikes/
Pretty easy to make your own though I am sure! Lots of ideas anyway...
I'm referencing the difference of how handlebars attach to low-crown forked bicycles and 'dual-crown' bicycles/motorcycles. Your handlebars could easily have better twist-alignment rigidity by adding brackets from each side of the handlebar to the tube near it.Sean9002 said:gogo said:Thanks for posting this up.
You've lost me on the bottom part. Could you clarify it a bit for me, as theres still time to make solid changes. Cheers for the input!
gogo said:I'm referencing the difference of how handlebars attach to low-crown forked bicycles and 'dual-crown' bicycles/motorcycles. Your handlebars could easily have better twist-alignment rigidity by adding brackets from each side of the handlebar to the tube near it.Sean9002 said:gogo said:Thanks for posting this up.
I've had the handlebars lose alignment in a 'crash' and then tried to quickly steer the bike again. It takes a few moments to realize the bars are out of alignment and adjust myself mentally. Sometimes you have just seconds to maneuver out of danger. I prefer the motorcycle convention of tying the handlebars to parts of the fork in a way that won't allow misalignment.
I have a feet-forward stretch cruiser and I frequently think about adding spring loaded foot pegs to stand on while going over big bumps. Have you had such thoughts?
Sean9002 said:Noph said:Hi.. This is nice to know someone is working on the same frame build. Love it. Thanks for sharing.
Hey Noph!
Yeh i think there is a couple of 'ghost' builds going on in the background. Do you have a thread going for your bike?
I love those bars! Badass! Is that rear a 100mm rim? What are your battery plans as the tank area is filled in. Ive been looking at tilising the space between tyre and seat stay, its a big area, and i could make a nice curved tank that the fender could integrate into.
Samd said:Sweet!
Just got a dozen of 80mm wide by 24 inch rims, don't quite fit the micargi, time to get out the drift hammer and wood blocks. Still got a few ally core fronts if you're up for dual drive!
Oh man those tyres look so sweet!
Sean9002 said:Dual drive would be greaaaaaat fun . However I'd need a soloution to make it run a 20mm through axle dirt jump axle to fit the forks.
arkmundi said:There are a rare few here on the forum that approach that meld of form, function, beauty and raw-steel-speed, when you're not sure they're artist, craftsman or part of the technorati elite. My MXUS 3K sits in a box and may stay there awhile as I now aspire to a higher standard. Please show mercy for the maker-challenged. Mucho-respecto!
Samd said:That colour is awesome!
I've been thinking of a solution for front axles in a 20mm front and I think I have either come up with it, or I am recalling how Kingfish did it. Either way.
My solution is to remove both stanchions, run laser cut washers inside the 20mm hole and clamp the ends with both stanchions off the bike, then insert the stanchions afterward to both crowns, pretightened. It might work, need to check. Spinout could be halted by running one plate external at each end like a torque arm...
Hmm, more thinking beer needed...
Samd said:Well strictly no, you could cut the old one off.
But it doesn't give you much choice for getting a new one on however.
Oi! Drop yer stanchions!
I've never seen those front forks before, but was thinking of doing it on some older boxxers from the shed, for a trial with dual BPM offroad. Are they a 100mm wide hub or a 110 wide DH style 20mm axle?
Sean9002 said:
219 Gokart sprocket carrier. only $50AUD, would be a good way for someone to go a Gokart chain on a bike. all you need is a 6 bolt iso hub (flip flop fixie style)
Lenk42602 said:Sean9002 said:219 Gokart sprocket carrier. only $50AUD, would be a good way for someone to go a Gokart chain on a bike. all you need is a 6 bolt iso hub (flip flop fixie style)
Nice work!
Can you provide a link to this carrier?
Cheers,
len
