Sorry if this bike has already been mentioned but it looks like a pretty sweet ride! If I had the money, I might go for this one but instead I'm in the process of building my own.
Yup, it's a rear hub motor. I'm not sure but the batteries might be mounted in the frame. It's a bit overpriced and as much as I love the wheels and look of this bike I think I might do an e-bike build with a downhill bike like others here.
I test rode one the other day but the battery was about dead It has a 36 volt lithium battery that is inserted into the frame right below the pedals. There is a rail on the back of the bike where a second battery can slide on. I test rode ultramotors other bikes to, slow but fun. The europa had a heinzman motor but the other two didn't.
Here is a battery out of a Europa 10 ah 36 volt, comes off charger at 41 volts.
Nice box with a handle an on off switch charge port and outlet.
Also a 30 amp fuse inline.
A no return eebaybuy so no warranty to me lets look inside
Sure hope the bms on top is a very good one. It will be charged outdoors.
I have no other specs on this set up.
The europa battery box almost fits right into an E V global frame. They have a different power outlet ,
and the europa battery switch will flip to the on position when the outer battery door is closed.
This battery weighs in at 8 1/2 pounds.
