MrDude_1
Power poster
So I am trying to work out a math problem, but I have no Thermodynamics education other that what I have picked up here and there... Hopefully one of you engineers can help me out. Here’s what I am trying to solve:
I have a small ebike controller that can push 80amps, and then rolls back power as it heats up. In still air on the table, it stabilizes at 40a.
I am mounting it to a block of aluminum as a big heat sink. The controller bolts to this block, and then the block bolts to the aluminum case. The idea being the block will spread the heat from the controller out over a large area of the case. I have enough room to make a 3 inch by 4 inch block up to 2 inches thick. If possible, I would like the block large enough that it can keep the device at 80a capable for the entire battery run. We can assume I am running flat out all the time, with the only stops being for occasional intersections, and even then I am pulling away at full throttle.
The battery I have is 20ah (manufacturer rated) of 16s lipo, charged to 4.15 per cell (66.4v) and never discharged below 3.6.
So, I figure the simplest way to solve this is look at the wattage the controller is dumping as heat, and then see how long it would take to heat the block of aluminum, assuming it’s not losing any heat... so I was looking for some formulas. I decided to attack what I could.
Phase Wattage 80a - 40a
4736 - 2368 @ 3.7 * 16 (59.2)
5312 - 2656 @ 4.15 * 16 (66.4)
Let’s assume a worse case of controller is 80% efficient and always run at max voltage and full throttle.
So at the full 5312 watts of output, it may be making 1,062.4 watts of heat?
This seems oddly high, but things do get hot, so I'll go with it... now watts is an instantaneous unit of measure, I know I'll need time in there.
If I have a 20 amp hour battery, that means that pulling 80a from it (20/80=.25) so 15 minutes of time.
Now, at what temp does it start pulling power... I don’t know... but going off the "I don’t want my hand on it" amounts, I would say 180*F is pretty hot.
Going from 80*f (I live in a hot area) to 180f is a delta of 100 (if I am saying that right.
So my numbers would be 1,062.4 watts of heat for 15 mins to raise the temp 100*f
Looking online to try to find out what I need to know I found this:
from: http://farnam-custom.com/resources/engineer-talk/how-much-wattage-do-i-need/
Cool I figured I could find the weight of aluminum block that I would need, and then using its density I could figure out what thickness of a 3"x4" size I would need.
So plugging in my numbers I get:
1062 = .018 x Lbs of alum x (180-80) / .25
Using math I haven’t used since school I work out:
1062*.25=.018 x Lbs of alum x (180-80)
265.5 = .018 x Lbs of alum x 100
(265.5/.018)=Lbs of alum x 100
(265.5/.018)/100=Lbs of alum
147.50 = Lbs of alum
So 147.5lbs... will hit 180* by my controller in 15mins. Clearly I am an idiot that has no idea what I am doing.
So... can someone help me? Is my controller heating assumption too large? Or does air really cool that well? or is this what I should expect to have as a thermal heatsink that big?
Im limited in footprint to 3x4.. so at 1 inch thick thats 12 cubic inches of aluminum, or 1.176 pounds 2.352 if I go 2 inches thick.
Other than just saying screw the math and buying the largest block I can fit, is there any way to work this out?
Below are some good guidelines for heating different materials in different situations.
To calculate the wattage requirement to heat steel, use the following equation:
Watts = 0.05 x Lbs of Steel x ΔT (in °F) / Heat-Up Time (in hrs)
Example: To heat 50 lbs of steel by 250°F in 1 hour; .05 x 50 x 250 / 1 = 625 Watts. Using the same example, reaching temperature in 15 minutes (0.25 hrs); .05 x 50 x 250 / .25 = 2,500 Watts. This equation is suitable for mild and stainless steels. If you are heating a different material than steel, you can replace the 0.05 in the equation above with the following coefficients:
Brass: 0.053
Aluminum: 0.018
Copper: 0.056
