The motors have such low inductance, they actually make external inductor sets to go in series with each phase wire just to try to make possible to control.
This has a double wammy against finding a controller for it. Super high pole count means electrical RPM is going to be higher than a Sevcon/Curtis/Kelly can achieve to get it into it's power band, and super low inductance means no RC controller would be capable of any degree of phase current control and will turn into smoke.
It would likely require something along the lines of the KERS motor controllers to use to full potential. Similar to the solid slot motors, which are absolutely rocking motors, but mostly useless because the only things that can run them somewhat effectively cost 10x more than the motor itself.
