kalevvaska
- Joined
- May 5, 2020
- Messages
- 37
What about trails? I was kinda hoping it would be a dual-sport. I’m willing to modify if I have to to make it work.
kalevvaska said:I think I’ll take your advice. I’ll try out the RCP and if it doesn’t work I can upgrade to a more sturdy shock. Thanks! By the way, how were you able to mount the bigger shock? What did you modify?
kalevvaska said:It’s looking good! What else do you have to do?
Aussie-guy said:the controller isn’t giving any errors but the TFT is telling me 40H hall sensor everytime I turn the wheel
My guess from seeing this kind of problem many times over decades, is that something became unseated, pulled loose, or a wire broken at the back of a contact, or there is a spread contact in a connector so that when taping wires they changed the angle the wire pulls at the contact, and so doesn't make contact (or not full contact) anymore.Aussie-guy said:cable sorting taping and the like.
<snip>
Pulled all the wiring out and checked the connectors, might have to de-glue the connector (added too much to the back of the plug to unplug it) and try the spare hall connector tomorrow.
It does, if you get an error on the display, it comes from the controller.The thing I found weird was the control doesn’t see an error.
Tolkano said:Aussie-guy said:I did look at that option and while they look great, the performance is still not quite up to scratch speed wise, also it’s double the amount that I’m spendingtolkaNo said:I'd buy a sur-ron instead
It's gonna weigh a tonne, won't offroad well, won't look like a bicycle on the road, and won't be as cheap as you think it will be
There's still ways to do the build you want to do but qs273 on trails/offroad isn't it
