mannydantyla
⚡ Regular
- Joined
- Dec 4, 2020
- Messages
- 127
Hello! I'm so excited I just found this thread! I too am converting a '60s Benly/Baby Dream to EV! Mine is a '67 CA160, I bought it about a week ago, and it has a seized motor. I think the curvy shape and size of these small '60s Hondas are perfect for EV. Here's mine: https://www.vintagehondatwins.com/forums/showthread.php?2054-CA160-EV-Conversion
Everything you're doing to your build, I have been planning for my own build as well. Same speed and power, even. So this is going to be so helpful! All the advice in here will apply to me as well.
I too will probably use a QS motor. What model number is yours? Is it the 205? What width is the rim? Does the hub fit between the swing arms without needing to widen them?
What happened to the cylindrical shape of the battery box you talked about in one of the first posts? I would like a battery box that is anything but a cube. Even if that means sacrificing range. Something like this would be amazing.
I am still deciding but I'm wondering if I could get enough range out of 25Ah. If I could use 20 LiFePO2 25Ah batteries wired all in series to get 64v 25Ah (1.6kWh) then I think that would be perfect for me. Micah Toll says expected consumption is 50 Wh/mile at 30mph, and 1.6kWh / 50kW/m = 32 miles. And I like LiFePO2 batteries because they'll last forever and are more eco friendly.
But would a lower capacity of 25Ah effect the take off speed that the motor and controller can provide? Will that depend on the controller? I calculate for a 20s1p config: continuous current = 75 amps = 4.8kw @ 64v (nominal) and 5.4 kw @ 72v (max charge). And max current = 125 amps = 8kw @ 64v (nominal) and 9kw @ 72v (max charge). But for the Kelly controller, 160amp is the smallest current that can be selected on their website.
Sorry for all the questions! Keep up the good work! I'm eager to see how fast and quick your bike is once assembled!
Oh and one last thing! I can assure you that 75mph was not the top speed of the original ICE bike. It only had 4 gears and not enough HP. I have a 200cc Honda with 5 gears, new piston rings, and it gets up to 60mph tops, downhill only.
