toddbailey said:
'm finding the Li battery packs quite expensive, LiFePO4 are not even close to my budget. Enter the old tech of SLA batteries,
A number of threads discussing the options
https://endless-sphere.com/forums/search.php?keywords=SLA+lithium&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
https://endless-sphere.com/forums/search.php?keywords=lead+lithium&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
There are lots of others under other search terms. this is a list of all the topics with SLA or Lead in the title, so has lots of irrelevant threads, but many relevant ones
https://endless-sphere.com/forums/search.php?keywords=SLA&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
https://endless-sphere.com/forums/search.php?keywords=lead&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
I need 36 volt at 12 amp/hr, I am thinking of 3x or 4x 15 to 20 amp/hr agm/sli deep cycle batteries in series. and a 3 or 4 simple 1 amp wall warts to recharge.
You can't use 4 in series to get 36v. You must use 3.
FWIW, I did exactly what you're talking about, because I couldn't afford anything better, and cooked the SLA pretty quickly, way back on the DayGlo Avenger's first operational motor system a decade ago. So here's some tips I learned the hard way:
If you use "wallwarts" then you must use ones that are current-limited so you don't burn them out or end up with a fire in the wallwart (meaning, intended as LED power supplies or as battery chargers), and they must be the right voltage for the full charge of SLA.
If they are not SLA-specific chargers you should stick with 13.6v units so when you leave htem on too long you don't destroy your batteries. If you use "12v" wallwarts you are not actually charging your batteries, as 12v is the reocmmended "empty" voltage (about 50% capacity). Don't use the heavy transformer type wallwarts; they're unregulated and will destroy your SLA by overcharging and boiling them (assuming they don't just burn themselves out or catch fire).
If you use mroe than about 50% of SLA capacity you will greatly reduce their lifespan, and will probably end up replacing them every 6 months to a year depending on how much you use the bike.
If you don't immediately recharge them as soon as you stop at the end of the ride, the SLA will be damaged (sulfated), more and more the longer they are left in a non-full state.
If you don't use them for a while, you need to maintain them by topping off their charge, and monitoring their voltage, or just like the above you will sulfate them and damage them as they self-discharge.
Since you can't (shouldn't) use more htan half the capacity of the lead, you have to use twice as much battery as you would with other chemistries to make up for that.
Since the way they measure capacity on lead is different from everything else, where lead is measured at a discharge rate (current) 1/20th or less than that you'd actually be using (and that which Lithium is measured at), you won't get anywhere near the actual capacity listed on the batteries, maybe half or perhaps a bit more (sometimes less). So you then have to also double the pack size for that reason, too.
That means you may need a pack up to four times the size you think you do to get the same range out of it without overtaxing the lead batteries and greatly shortening their lifespan. That means four times the size, and four times the already very heavy weight.
Those are all reasons why people use almost anything *other* than lead, as it is not actually cheaper except possibly on initial setup cost if you go really really cheap on everything...but it won't last anywhere near as long as a decent Lithium battery. So if you literally cant' afford anything else, and *have* to motorize it *now*, you could go for SLA while you save up for a good Lithium battery...but if you can afford to wait and save up now, that's cheaper in the long run.
Don't cheap out on the Lithium battery, either--there are LOTS of garbage ones out there. So look around the forums at the many threads about various batteries and projects like yours with needs like yours, and see what they used and what their results were (if they report them), and don't get the stuff that had problems.
Only get the stuff reported as good.
