Hi Endless Sphere,
Preaching to the converted
I recently borrowed an e-bike and, wow, you folks sure are onto something! It is the best form of transport I have ever used, quicker and cheaper than public transport. And, around the inner city, it is actually quicker than a car. Incredible!
So now I ask for your help to get one for myself...
Usage
- maximum speed 40 km/h edit 30/3: for bursts only, cruising speed slower and with pedal assist
- range of 50km assisted (I pedal at a comfortable non-sweaty level, while the motor does the hard work. My typical consumption is 12 Whr/km) edit 30/3: my regular commute is a 25km round trip, but I'd like more range for other trips
- road usage and some gravel bike paths, but no off-road mud-bashing
- good resistance against punctures and bent rims (I have been getting a lot of flats on my road bike which has been very frustrating)
- wet weather friendly
- battery needs to be charged separate to the bike, since I don't have a powerpoint where the bike is stored
- doesn't look like an e-bike to the average driver
Many thanks to kabbage for the "test rides" of his setup, it is a wonderful machine. Some changes I'd like for my e-bike are less tail-heavy handling, faster when human powered and ease of battery removal. I think lighter batteries mounted within the triangle will go a long way regarding the first two points.
Current plans
edit 30/3: Base bike will be a lightweight hybrid or mountain bike. Old text below:
Mountain bikes generally don't float my boat (extra weight, also I prefer the feel without suspension). Ideally, I'd convert a flat bar road bike like my Apollo Fiamme, but for starters the wide tyres won't fit. So I'm leaning towards a hybrid frame, unless I can find a lightweight and suspension-less MTB for cheap.
As for the e-bits, I really like the BPM 36V500W 11T motor (could possibly downsize to the 250W but the 500W isn't too heavy and leaves headroom if I get the power bug in future) and 25 amp C7225-NC controller's performance kabbage uses, so I'll stick with that. Also, a hand throttle and Cycle Analyst like his are part of the plan.
The battery is still undecided, aside from going 48v, mounting it as low as possible in the triangle and having it easily removable (for charging and to take it with me when I park somewhere dodgy). 12Ah is plenty for me, I could even come down a bit from that. LiPo is tempting, if I'm brave enough. Actually, I've just had a crazy idea of having half the capacity and carrying a second battery when I need more range. This also makes charging easier, I just swap in the other battery so I'm not waiting for it to recharge. This means that the extra weight of LiFePo4 isn't a problem, so I'm quite excited by this idea.
To not look like an e-bike, I'd like all the electronics tucked away in non-descript weatherproof bags/containers.
For packaging and simplicity reasons, I'm thinking of sticking with rim brakes. They would be upgraded with Kool Stop pads and, if that's not enough, Avid SD7 calipers.
The Mavic downhill rear wheel and Schwalbe Marathon combo on kabbage's setup is wonderfully tough. Possibly overkill, but I'd prefer to err on this side than be dealing with punctures etc. Although if they came in narrower widths, I'd be interested, because it'd give me more options in choice of frame.
For the gearing, 3 ratios on the front chainring and locking/removing the rear cassette has worked fine. Just in case it affects the conversion, I should mention that I'm planning on 1x side pannier bag.
I'm reasonably handy with tools (I do occasional maintenance on my bike, and regularly work on my old car), but copying a proven recipe on here would make things a lot easier. So if you can think of any build threads with similar goals, it would be much appreciated if you could post the link.
And any thoughts on my plans would be much appreciated, please.
First step- get the bike for the conversion
From what I've read here, I should watch out for rear dropout strength. How do I check this on potential purchases?
Will torque arms work with my plans? How do I check the bike is suited to adding torque arms?
What else should I look for on a hybrid bike that will be converted?
I've noticed that most hybrid/road e-bikes on here use front hubs. Why is this?
Many thanks,
Simon
Usage
Current plans
Many thanks,
Simon
