nechaus
:lol:
id like to know a diy method of producing heaps of watts
Dauntless said:http://phys.org/news/2013-01-paves-larger-safer-lithium-ion.html
Don't know if this one made it up before or not, but not to be missed.
Yea, the gov't will either tax you on that, or will find another way of squeezing more dollars out of you.gestalt said:3d printed concrete structure+wood battery+renewable energy= win for sustainable affordable housing for all.
cal3thousand said:How come they aren't using hemp, I wonder?
Dauntless said:cal3thousand said:How come they aren't using hemp, I wonder?
Hemp? Expensive, illegal, less effective. Compelling argumentsbvagainst the use.
Snip....The new ionically-conductive cathode enabled the ORNL battery to maintain a capacity of 1200 milliamp-hours (mAh) per gram after 300 charge-discharge cycles at 60 degrees Celsius. For comparison, a traditional lithium-ion battery cathode has an average capacity between 140-170 mAh/g. Because lithium-sulfur batteries deliver about half the voltage of lithium-ion versions, this eight-fold increase in capacity demonstrated in the ORNL battery cathode translates into four times the gravimetric energy density of lithium-ion technologies, explained Liang. ....snip
http://www.ornl.gov/info/press_releases/get_press_release.cfm?ReleaseNumber=mr20130605-00
Media Contact: Morgan McCorkle
Communications and Media Relations
865.574.7308
New all-solid sulfur-based battery outperforms lithium-ion technology
A new all-solid lithium-sulfur battery developed by an Oak Ridge National Laboratory team led by Chengdu Liang has the potential to reduce cost, increase performance and improve safety compared with existing designs.
A new all-solid lithium-sulfur battery developed by an Oak Ridge National Laboratory team led by Chengdu Liang has the potential to reduce cost, increase performance and improve safety compared with existing designs. (hi-res image)
OAK RIDGE, Tenn., June 5, 2013 — Scientists at the Department of Energy's Oak Ridge National Laboratory have designed and tested an all-solid lithium-sulfur battery with approximately four times the energy density of conventional lithium-ion technologies that power today's electronics.
The ORNL battery design, which uses abundant low-cost elemental sulfur, also addresses flammability concerns experienced by other chemistries.
"Our approach is a complete change from the current battery concept of two electrodes joined by a liquid electrolyte, which has been used over the last 150 to 200 years," said Chengdu Liang, lead author on the ORNL study published this week in Angewandte Chemie International Edition.
Scientists have been excited about the potential of lithium-sulfur batteries for decades, but long-lasting, large-scale versions for commercial applications have proven elusive. Researchers were stuck with a catch-22 created by the battery's use of liquid electrolytes: On one hand, the liquid helped conduct ions through the battery by allowing lithium polysulfide compounds to dissolve. The downside, however, was that the same dissolution process caused the battery to prematurely break down.
The ORNL team overcame these barriers by first synthesizing a never-before-seen class of sulfur-rich materials that conduct ions as well as the lithium metal oxides conventionally used in the battery's cathode. Liang's team then combined the new sulfur-rich cathode and a lithium anode with a solid electrolyte material, also developed at ORNL, to create an energy-dense, all-solid battery.
"This game-changing shift from liquid to solid electrolytes eliminates the problem of sulfur dissolution and enables us to deliver on the promise of lithium-sulfur batteries," Liang said. "Our battery design has real potential to reduce cost, increase energy density and improve safety compared with existing lithium-ion technologies."
The team's all-solid design also increases battery safety by eliminating flammable liquid electrolytes that can react with lithium metal. Chief among the ORNL battery's other advantages is its use of elemental sulfur, a plentiful industrial byproduct of petroleum processing.
"Sulfur is practically free," Liang said. "Not only does sulfur store much more energy than the transition metal compounds used in lithium-ion battery cathodes, but a lithium-sulfur device could help recycle a waste product into a useful technology."
Although the team's new battery is still in the demonstration stage, Liang and his colleagues hope to see their research move quickly from the laboratory into commercial applications. A patent on the team's design is pending.
"This project represents a synergy between basic science and applied research," Liang said. "We used fundamental research to understand a scientific phenomenon, identified the problem and then created the right material to solve that problem, which led to the success of a device with real-world applications."
The study is published as "Lithium Polysulfidophosphates: A Family of Lithium-Conducting Sulfur-Rich Compounds for Lithium-Sulfur Batteries," and is available online at http://dx.doi.org/10.1002/anie.201300680 . In addition to Liang, coauthors are ORNL's Zhan Lin, Zengcai Liu, Wujun Fu and Nancy Dudney.
The research was sponsored by the U.S. Department of Energy, through the Office of Energy Efficiency and Renewable Energy's Vehicle Technologies Office. The investigation of the ionic conductivity of the new compounds was supported by the Department's Office of Science.
The synthesis and characterization was conducted at the Center for Nanophase Materials Sciences at ORNL. CNMS is one of the five DOE Nanoscale Science Research Centers supported by the DOE Office of Science, premier national user facilities for interdisciplinary research at the nanoscale. Together the NSRCs comprise a suite of complementary facilities that provide researchers with state-of-the-art capabilities to fabricate, process, characterize and model nanoscale materials, and constitute the largest infrastructure investment of the National Nanotechnology Initiative. The NSRCs are located at DOE's Argonne, Brookhaven, Lawrence Berkeley, Oak Ridge and Sandia and Los Alamos national laboratories. For more information about the DOE NSRCs, please visit http://science.energy.gov/bes/suf/user-facilities/nanoscale-science-research-centers .
UT-Battelle manages ORNL for the Office of Science. The Office of Science is the single largest supporter of basic research in the physical sciences in the Unite
??? ..isn't this a Lithium sulphur cell..?...wake me when they have a buy now button
The big idea behind Joe's Big Idea is to report on interesting inventions and inventors. When I saw the headline "An Environmentally Friendly Battery Made From Wood," on a press release recently, I figured it fit the bill, so went to investigate.
The battery is being developed at the Energy Research Center at the University of Maryland in College Park.
I really wasn't sure what a wood battery would look like. I knew you could make a battery out of a potato and wires, so I figured maybe they were doing something similar with a block of wood.
Wrong. The "wood" is actually microscopic wood fibers that are fashioned into thin sheets. The sheets are then coated with carbon nanotubes and packed into small metal discs.
The wood batteries use sodium ions, rather than the lithium ions that are found in the batteries of cellphones and laptops. In this case, the charged particles move around in the wood fibers, creating an electric current. It turns out wood is a good medium for sodium ions to move around in.
Now, wood is comparatively cheap. So is sodium. Liangbing Hu, head of the battery project, says he's hoping the new batteries can be scaled up so they'll be useful for storing the vast amounts of energy generated by solar arrays or wind farms.
"I think this wood-based storage can play a very important role as a low-cost solution," he says.
Right now the battery is just a prototype. Hu and his colleagues will need to tweak the materials before they have something commercially viable.
There was something else interesting about the new battery: One of the authors on the paper describing it in Nano Letters was an undergraduate. What's up with that? How does a young college student wind up co-authoring a paper in a major scientific journal?
Hu says Nicholas Weadock was an engineering major who expressed an interest in working in the lab. "In the very beginning he was helping students, my Ph.D. students actually, correct some English grammar," says Hu. A lot of Dr. Hu's doctoral students are from outside the U.S. "During the process ... he asked a lot of interesting, very insightful questions, not only about the language, but about the science behind it."
Weadock says he had originally wanted to work on wind power, but became interested in energy storage technology and wanted to show Hu that he could be a contributor to the lab.
"I came to the group meetings, I made suggestions, and I was ambitious enough to show him that I can do my own project," he says.
Weadock is off to the California Institute of Technology in the fall for graduate school, where he plans to continue work on energy storage. Hu says the positive experience with Weadock has convinced him to recruit more undergraduates to his lab.
Hillhater said:??? ..isn't this a Lithium sulphur cell..? and 170whr/kg....wake me when they have a buy now button
