I rebuilt my bike to make some upgrades, and after getting everything put back together and all the electronics plugged back in, my throttle is being really weird.
My bike has:
QS205 motor
SVMC 72150 controller
Domino throttle
It went like this:
1. I redid the hall test because I had unplugged everything, so I assumed it had lost its memory. Hall test was all normal, just like when I've done it in the past, no obvious issues. MQCON app said normal and fault free.
2. I go to test it and the throttle doesn't respond on twisting it. So I continue to twist and almost at the very end of the travel the bike groans forward an inch and stops. Throttle is now completely dead, and app is saying system error, fault type hall.
3. I turn everything off and back on again, and the MQCON app is again saying fault free.
4. Try the throttle again, the exact same thing happens.
I triple checked my throttle wiring against the various manufacturer diagrams. It's the same throttle that was working for years. So I don't think it's miswired or that it just happened to go out. I'm thinking there has to be a loose connection somewhere.
I've asked around on FB, and people have suggested throttle, hall sensors, and phase wires; but everyone was just spitballing. I feel like someone who really knows how these things work would be able to narrow down what I should look at first before I start ordering replacement parts/pulling all my wiring out. I'm hoping to get this solved as quickly and inexpensively as possible. I live downtown where parking is scarce so this is my primary transportation down here.
Update: In the MQCON phone app, the main screen is showing the throttle's resting voltage to be .02v.
I have absolutely exhausted all resources checking to make sure the throttle is wired correctly. I've metered out the wires coming from the controller and checked and double and triple checked the wiring diagrams from the controller and throttle, and I can't find any possibility that I've miswired it.
My bike has:
QS205 motor
Domino throttle
It went like this:
