Electric Earth
- Joined
- Nov 11, 2018
- Messages
- 127
I'm still on my first e-bike, so I don't know much beyond my current set-up. My throttle is too bulky to use my trigger shifter normally, so I have the shifter flipped up awkwardly behind the throttle. Will most half-twist throttles(seems like most prefer those, so I'm gonna try one) work with trigger shifters as long as there isn't a switch built in below the handlebar, or is the throttle mechanism just too bulky to fit between the shifter and bars? If they'll work together, any suggestions on a cheap one to test and see if I like the half-twist style? My current throttle has a cut-off switch and battery bar LCD. It would be nice to keep them if possible. I'm not interested in losing my front shifter, so simply using a left side throttle won't solve my problem. So basically...
1. Will a half-twist work with trigger shifters?
2. If so, any cheap suggestions to try it out?
3. If it won't work with trigger shifters, what are the options for trigger shifters and a throttle?
Current throttle - https://www.alibaba.com/product-detail/WUXING-electric-twist-bike-throttle_60812319786.html?spm=a2700.7724857.normalList.6.10411fc8LlS61A&s=p
