999zip999
100 TW
Ok the tire has not slipped with the gasket cinch on the tire and rim. So the tire almost bald now and has not slipped yet 6400 watts.
Tony01 said:you guys must be doing something wrong. in over 20,000 miles of riding hard and fast on bicycle tires this has never happened. I have also never blown a tire off the rim. A good portion were on chrome rims as well.. which have about half the friction coefficient of aluminum.
Combinations that have worked for me: thorn resistant tubes (heavy ones but not slime) with Kenda Kwest 26x1.95, CST cyclops 26x2.4, hookworm 26x2.5, duro 26x3.0, and one small kenda 26x1.95 tire with the raised tread sides.
Maybe you are not getting those tires seated correctly? or maybe your tires just suck? ...
MadRhino said:Electric torque is hard as compared to gassers. High power ebikes have the torque of MX motorcycles. You will soon experience the efficiency of power transfer that is possible to achieve building EV.
Of course we need to care properly mounting quality rims and tires, but nevertheless bicycle tires slipping on rims above 10 kw acceleration is not uncommon. I feed 20+ kw in acceleration and some tacky compound on the bead is a must. The smaller MX bead locks can be fitted on some bicycle rims, but they do affect wheel balance much more on a lighter wheel than MX wheels.
Tony01 said:...
Just a thought though, maybe you can look into alloy rims that have a bigger beat seat area? Like the worksman alloy rims?
