Science Faction
- Joined
- May 18, 2009
- Messages
- 59
HI all,
In January I purchased 18 x nanotech 6S 25-50C 8AH blocks and they all arrived very well balanced at 22.9V.
I built 2 x 18S 2P packs with an 18S 60a BMS for some friends.
I have just been using 3 packs in an 18S 1P config in a backpack for myself.
Bad news, first after only 150Kms, not even 5 or 6 cycles and no hard work, 40Amp max draw, my 3 6S packs have gone puffy.
Yesterday one of my friends packs stopped charging so I pulled the batteries out of the box and of these 6, 1 was puffy and 4 were a little puffy and 1 normal.
One pair of paralleled cells had dropped to 1.8 V.
They were in position 13 in the BMS.
This is the first cell from the positive output of the 18S battery pack, ie closest to the bms in terms of current flow.
So i got a little suss on the BMS.
I replaced the dud cell packs with two of my 6S packs with matching voltages to each other and the other 4 packs and charged them to 76V.
These BMS's max out at 4.26V
The pack charged normally with all the cells resting on 4.21 - 4.22V with a max delta V within each 6S being 15mV.
I unplugged the cellogs and in the morning checked the cells again to find that the cells in position 13 had dropped to 4.17V, witha deltaV in that 6S pack of 54mV.
So I can't blame the nanotech's for the dud cell just yet, as it may be the BMS.
Will keep you posted.
I am going to investigate the other 18S 2P pack today.
I found this thread after this problem arose and i so so wish I had seen it before I ordered what I though were a higher quality product than the zippy's, although Lukes comment about the change in quality was in Feb and after I had ordered anyway.
I just hope like others i can get warranty.
I believe it is totally inexcusable to reduce the quality of a product especially when it is marketed as the premium product.
Cheers
Paul
Cheers
Paul
