[edited heavily from the first post, so the first reply may not make much sense with the new post]
I've spent some time tonight trying to figure out a way to mount the ebikes.ca torque arm on my sprint-26 , and this is the best that I can come up with:
If the axle and joint are all tightened down really tight, and I screw a hose clamp around the area noted with the blue arrow, is that sufficient?
The other option is to put a spacer (~1/4") between the dropout and the torque arm. That would allow the bent part to clear the frame and the straight part would rest above the Inline image 1rim mount. The only problem is that it wouldn't be flush with the frame, there would be about a 1/8" gap. The second attached photo shows the alignment I'm talking about on the top.
Are either of these valid installations, and is one better than the other?
Thanks!
Thanks!
