Catalyst82
Heres my set up...
Smartpie hub motor
Thun bb torque senor
Cycle analyst V3
Grin tech 1m ohm shunt
Heres my problem.....I cant get the motor to turn on when torque is applied to the pedals. I have a magure twist throttle i can plug into the throttle input of the cycle analyst and the motor will turn just fine, so there is output going from the cycle analyst to the motor/contorller. So maybe there is some setting within the cycle analyst that is not turned on or not correct?? Can anyone share there settings? There is 10v power going into the thun, which from what i understand is sufficent for it to operate, and my cycle analyst displays any torque that is applied and a reading of 2.45V from the thun. But nothing seems to be getting output from the cycle analyst to the motor. My output plug from the cycle analyst is connected to the 1m shunt, which is in turn connected with the green wire only (signal wire) to the green signal wire going to the motor. So why does the twist throttle work but my torque sensor doesnt?? Thanks in advance for replying
Smartpie hub motor
Cycle analyst V3
