Good day everyone,
Recently, i bought very cheap (less than 200$) five motors and one battery from two guys who wished to keep their bikes as non-electric.
The battery is TranzX BL03 2014 model (36v / 9.9A) disassembled from a Hercules Tourer AGT 7 (automatic trans for Nexus 7)... it has come with the TranzX "huge" (10 pins) motor hub, two controllers (one main and a secondary controller) LCD display, AGT device, switches, but without torque sensor, without brake sensor handles. Also it seems that this is only assisted and have no throttle.
Other hub motors I have are all 36V 250 to 400W as fallows:
-Schachner- brushed motor made in Austria, with controller, but without PAS senor who have four wires instead three !!?
-Schachner- brushless with controller also made in Austria, but I actually find that is Tongsheng the main producer... instead, the brushed one it seems that is fully made in Austria.
-Tongsheng (aka Qute Q100 In my opinion)- brushless, just 3 whires (perhaps it have the HALL sensors inside or outside) and was come without controller, just LED display and sensored brake handles.
-MXUS BF08 (designed for rear wheel) with controller.
-And as I said first, an Tranz X motor hub very heavy and so ugly LOL.
From now I'm a little confused because, at least theoretical, I have all I need to transform my trekking bike Pegasus into an E-bike, but with all this, I don't know what to choose. Also I have to tell that I do not have an magnet wheel for PAS sensor.
I'd like to choose the brushed one, just because it gives the best torque and this is actually what I need most... for my city full of hills.
The big and first question is:
The TranzX Battery, have four pins (one main "-" , one main "+" and another two secondary "-". I measured the full charged battery between all pins and result 41 Volts on main + and- pins, also 38 between both secondary - and main +. Another thing is that the motors& controllers I have, only act on main pins and do nothing if i use secondary "-".
So, after these explanations, can I use this battery with normal two wires controllers at normal capacity?
What is the purpose of the secondary "-" ?
Here I add a link with the plug of the battery http://www.pro-cycling-golla.de/images/artikel/artikel4fcb3adae3fd0_2.jpg
Thank You!
Thank You!
