eMark
Realize what you are attempting to communicate, but your exaggeration can easily give the wrong impression to others than what you intend to communicate. The PRIMARY task of a TRUE Balance Charger is charging (increasing the parallel cell voltages while balance charging) NOT "passive bleeding / resistive method" as with only 99.99% of BMSs :wink:john61ct said:99.99% of the hobby balance chargers out there use the exact same passive bleeding | resistive method as do most of the BMSs.
Whichever Lipo/Li-ion Balance Charger i use it's a TRUE balance charger as the parallel cell voltage increases as its PRIMARY task of increasing the cell voltages to the users desired level. Thus TRUE balance charging can never be achieved with a typical BMS "passive bleeding | resistive method".
IFWR i want to exactly equalize the parallel cell voltages (which practically isn't necessary), of my two 5S5P packs (10S5P battery) i use the following multi-purpose stand-alone discharge balancer. Even then it can take an hour to exactly equalize parallel group voltages that are already within 0.05v of each other ... so it's use isn't all that necessary when using a balance charger to begin with that equalizes the parallel group voltages within 0.05 volts of each other, if not closer ...
Because i still have a couple Lipos like new (3S 2200mAh & 3S2P 4400mAh) i can take them with me when etriking in case i need to charge my phone or bike light or easily separate and check voltages of the two 5S5P packs of my 10S5P battery. The USB and phone charge port is located on the right side. You press the middle button to see options such as "Start Charge" (actually discharge :wink: ). Very legible readout shows which parallel group(s) are too high and when all parallel cell groups are at same exact voltage and will then stop (shutdown). Instruction manual ... https://www.isdt.co/down/pdf/BG-8S_en.pdf ... the top photo is how the readout appears before pressing the "Start Balance" button and when pressing the "Start Balance" button whatever parallel group of cells having a higher voltage (slowly being discharged) appear in a redish brown color. After a minute the screen shuts down, but the discharge balancing is still activated. Press the middle button again whenever you want to see the cell voltages. As long the small blue light at the middle top is blinking it is discharge balancing even when the screen is off. It uses a XT60 connector.
Apparently you didn't read my concluding advice in my previous post ... so will paste again ...john61ct said:Your generally low opinion of BMS as balancing devices is not warranted, plenty of them are out there that perform perfectly well in that role.
Bottomline is that a BMS is still a good idea if only for protection(BPS)
