bruce.nali
10 µW
Thanks in advance for any help. I have a simple beach cruiser conversion I did about 18 years ago with a 400 watt front hub motor. In 2016 I put in my second Ping battery (36v 15Ah LifePO4 battery pack with a 36V High Rate BMS). About once per month I charge for 24 or more hours but otherwise charge for about 4 hrs per night.
Battery has worked great but now cuts out after a short ride or hills.
Following advice here on some great threads, I charged it for 48 hours. At end, charger was green but BMS lights were blinking, not steady. Took off the charger waited for the lights to go out and found the following cell voltages:
1. 3.91 (B- to first pin)
2. 3.31
3. 3.57
4. 3.48
5. 3.57
6. 3.57
7. 3.57
8.3.57
9. 3.56
10. 3.57
11. 3.31
12. 3.57
Same voltages when measuring unplugged from the BMS.
Are the cells likely to balance out if I leave it longer on the charger (weeks?) or have I just gotten my monies worth from the this old Ping stack?
Could the BMS be bad - if so not sure how to test.
If a new battery - recommendations for a Ping Li substitute for this low tech machine.
Thank you in advance for any help - this forum has been wonderful and great to see the evolution of the ebike.
Bruce
2. 3.31
3. 3.57
4. 3.48
5. 3.57
6. 3.57
7. 3.57
8.3.57
9. 3.56
10. 3.57
11. 3.31
12. 3.57
Bruce
