Hey everyone. Im new to the E longboard community and i have been searching the forums for sometime now. I haven't been able to really find any talk about trucks and motor mounts, specifically the bolt on type that torqueboard makes. I have a pair of paris 180mm trucks that which are black and I plan on using with orangatang kegel wheels. I am planning on using dual TorqueBoards E-Power Motor 6355 230KV which are 55mm in length and 63mm in diameter. I wanted to go with a 6S setup with dual HK x-car beast 150A esc's. The motors and the Esc are both sensored.
My question is with the motor mounts on paris truck, how sturdy are these motor mounts. Has anyone had any problems with them rotating on the round paris truck. I didn't want to weld them on because they were already painted black and i was getting black mounts as well.
My other question is has anyone had issues with the mounts and paris trucks being perpendicular to each other. There is a gradual sloping of the truck that starts about 1 inch from the end. I don't know how many people have had issues with this or if this is an issue.
My final question is with running a dual rear wheel setup is there even enough room to run two of the torqueboard 63mm motors if they are 55mm in length.
