Pomathoin
🧲 New user
Hello, screen says EO² which I believe is relating to the hall effect sensor. It came up intermittently at first with a reboot clearing it but now it's permanent. Motor was 2nd hand and I believe it has different firmware as no limit on assistance speed.
So far I've checked;
No cracks in axle around hall sensor
Continuity of 2 pin induction ring wiring
Wiring on torque sensor plate appears ok
Motor resistance and continuity
Motor has at some point got hot enough to stretch the long bolts so thought I'd burnt it out but it works on walk mode and has 0.04ohms on all windings. Thinking now that it could be the controller itself, or the hall sensor attached to the controller. Is it possible to cause demagnetisation from excessive heat?
It's a 6 pin setup so no brake sensors.
Is there any way to read the hall outputs with my setup or do I need a VLCD5 or other screen? Maybe the programming cable and laptop?
Prices for parts seem way higher than 2 years ago so I'm looking for any ideas that don't involve just replacing bits in the hope of finding the problem.
