Has anyone tried upgrading the hardware of this motor/controller to beef this thing up?
Like upgrading the:
-Mosfets to IRF4410A, which should be compatible without swapping out other components, such as resistors.
(TSDZ2 uses 6x TK80E08K3)
-Capacitors to 100V 470uF caps from the 60V caps, for higher voltage /max speeds
-Add solder to shunt and traces on the PCB
-upgrade the wiring to a heavier gauge
-serious temperature control, somehow
-Open source Firmware (or other modified firmware) compatiblity
Would the motor just burn the f*ck up?
Any comments would be appreciated, I have some spare parts from these kits I want to play with
Cheers
Like upgrading the:
Cheers
