TSDZ2 TSDZ2B cooling improvement elements & kits - NEW!
ebikestuff.eu
Poland
The e-bikestuff team introducing the latest solution to improve the cooling of the TSDZ2 and TSDZ2B motors.
Available in kits or individual elements:
TSDZ2/TSDZ2B cooling kits tests
Sets:
- TSDZ2 motor cooling improvement kit - basic - €29.16
(thermal conductive insert (insert, thermopad, torx screws M4x12 - 4pcs) + thermal conductive plate + thermal conductive paste)
- TSDZ2 motor cooling improvement kit - premium - €97.99
(housing heatsink (thermopad + screws) + body heatsink (thermopad + screws) + thermal conductive insert (insert, thermopad, torx screws M4x12 - 4pcs) + thermal conductive plate + thermal conductive ring (ring, thermopad, bushings - 2 pcs, screws M2.5x10 - 2 pcs) + thermal conductive paste + thermal conductive glue)
Elements:
- Thermal conductive insert - €19.83
(insert + thermopad + torx screws M4x12 - 4pcs)
- Thermal conductive ring - €8.63
(ring + thermopad + bushings - 2 pcs, screws M2.5x10 - 2 pcs)
- Thermal conductive plate - €5.83
(plate)
- Body heatsink - €35.00
(body heatsink + thermopad + screws)
- Housing heatsink - €30.33
(housing heatsink + thermopad + screws)
Please visit our store at e-bikestuff.com for other TSDZ2 and TSDZ2B spare parts, accessories, mods and motor kits
I'm interested in the basic kit, can you estimate shipping to BC, Canada? Would the shipping amount change much for 3 kits?
Oh, I thought you had the end plate insert which they show in 3 sizes. The one you got looks a lot like my original home built cooling mod but I used braided copper strapping. That worked well as confirmed by temp sensor but I had to use several layers and once they got deformed a bit made it hard to get the cover back on, especially after disassembling to grease the motor. I may redo mine to remove a layer of copper and use a thin thermal pad for the gap. Whatever it takes to make the cover fit. The solution you have is probably better since it will be stable as you disassemble it.
I have a tsdz2b but I only used this bit which comes in one size: Thermal conductive insert for TSDZ2
I ordered that, temp sensor and thermal paste
For the plate I guess its best to measure before ordering, I was too lazy to bother with that so hoped the ”insert” would suffice
My copper braid solution can be seen in post 196 here:
