IdleMind
A while ago there were some threads discussing solderless 18650 pack construction. This caught my interest enough that I wanted to give it a try. I am currently using a pack made of 14 HK 4s bricks (8s7p) and it works great, so I don't have an immediate need for a whole new pack. So to start with I am making a 1s35p pack to use as a booster for my current 8s Lipo pack which will bring it up to 9s.
The outer case is made from 2 inch PVC pipe. The cells are stacked 5 high and there are 7 cells per layer all connected in parallel. At one end there are 7 springs to compress each string of cells. Between each group of 7 cells there is a flexible copper plate to make electrical contact. The copper plate is .008 inch thick.
The pipe's ID is a bit too small to accept the 7 cells so first I turned the OD smaller in a lathe to make it more flexible, then I slit it lengthwise so it can be spread open enough to insert the cells. Here's how it looks with a group of cells inserted in one end, you can see how the split pipe tightly holds the cells.
It's held together with 2 end caps and 3 tie rods made of 10-24 threaded rod partly covered with shrink tube. Seven springs tension the rows of cells. There are 6 contact plates, the positive plates have raised bumps to assure they do not make contact with the cell case. Each contact plate has a 4mm female bullet connector for attachment to the wire harness. Here's a photo of the parts.
Here's a photo of the assembly and the assembly after taping.
These parts could be rearranged to make a 5s7p pack, and two packs put together for 10s7p.
I'm working on getting it mounted in my bikes trunk and will also be discharge testing it.
