Turnigy 130A Watt Meter, WILL IT GIVE AN AH RATING??
I'm using something similar to this on my sailboat solar power project (it's a clone of this). As far as I can tell it reads Ah only, and won't do Wh, which is kind of a bummer. But it if that's all you need it should work out well for you.
Mine does Wh, well it did when it worked. It has a display in the top left that cycles from Watts peak, Volts min, Amp hours, and Watt hours. Or something like that. I'm 90% sure it shows watt hours.
I'm using one of these on my bike and it does measure Wh (and Ah). I used it to capacity check my batteries before using them on the bike.
